13 years agoSimulating custom DDR controller with ALTMEMPHY using ModelSim-Altera Starter edition
I'm designing a custom DDR controller using one instance of the ALTMEMPHY generated with the MegaWizard Plug-in Manager. The simulation files generated using Quartus II version 11.1sp2 or 13.0sp1 are...
12 years agoHi,
Here are some Verilog code snips that are from my working design. It simulates in Modelsim and works on a NEEK development board (Cyclone III). DDR mphy(.pll_ref_clk(osc_clk), .global_reset_n(reset_n), .soft_reset_n(1'b1), .ctl_dqs_burst(ctl_dqs_burst), .ctl_wdata_valid(ctl_wdata_valid), .ctl_wdata(ctl_wdata), .ctl_dm(ctl_dm), .ctl_addr(ctl_addr), .ctl_ba(ctl_ba), .ctl_cas_n(ctl_cas_n), .ctl_cke(ctl_cke), .ctl_cs_n(ctl_cs_n), .ctl_odt(ctl_odt), .ctl_ras_n(ctl_ras_n), .ctl_we_n(ctl_we_n), .ctl_rst_n(reset_n), .ctl_mem_clk_disable(ctl_mem_clk_disable), .ctl_doing_rd(ctl_doing_rd), .ctl_cal_req(ctl_cal_req), .ctl_cal_byte_lane_sel_n(ctl_cal_byte_lane_sel_n), .ctl_clk(ctl_clk), .ctl_reset_n(ctl_reset_n), .ctl_wlat(ctl_wlat), .ctl_rdata(ctl_rdata), .ctl_rdata_valid(ctl_rdata_valid), .ctl_rlat(ctl_rlat), .ctl_cal_success(ctl_cal_success), .ctl_cal_fail(ctl_cal_fail), .ctl_cal_warning(ctl_cal_warning), // .dbg_clk(ctl_clk), .dbg_reset_n(ctl_reset_n), .dbg_addr(13'h0000), .dbg_wr(1'b0), .dbg_rd(1'b0), .dbg_cs(1'b0), .dbg_wr_data(32'h00000000), .dbg_rd_data(dbg_rd_data), .dbg_waitrequest(dbg_waitrequest), .reset_request_n(reset_request_n), // .mem_addr(ddr_addr), .mem_ba(ddr_ba), .mem_cas_n(ddr_cas_n), .mem_cke(ddr_cke), .mem_cs_n(ddr_cs_n), .mem_dm(ddr_dm), .mem_odt(mem_odt), .mem_ras_n(ddr_ras_n), .mem_we_n(ddr_we_n), .mem_reset_n(mem_reset_n), .mem_clk(ddr_clk), .mem_clk_n(ddr_clk_n), .mem_dq(ddr_dq), .mem_dqs(ddr_dqs), .mem_dqs_n(), // .aux_half_rate_clk(aux_half_rate_clk), .aux_full_rate_clk(aux_full_rate_clk)); The key to getting the ALTMEMPHY started is the initial state of inputs from the controller. The inputs must be in the initial state until "ctl_cal_success" is true. ctl_dqs_burst <= 2'b00; ctl_wdata_valid <= 2'b00; ctl_dm <= 4'b1111; ctl_addr <= 13'h0000; ctl_ba <= 2'b00; ctl_cke <= 1'b1; {ctl_cs_n, ctl_ras_n, ctl_cas_n, ctl_we_n} <= 4'b1111; ctl_mem_clk_disable <= 1'b0; ctl_doing_rd <= 2'b00; ctl_cal_req <= 1'b0; ctl_cal_byte_lane_sel_n <= 2'b00; I believe the important thing is to initialize inputs to their inactive states until the calibration process is complete (even when skipping calibration). It's been a while since I was working on this. So, I hope I didn't miss anything. Ken
