13 years agoSimulating custom DDR controller with ALTMEMPHY using ModelSim-Altera Starter edition
I'm designing a custom DDR controller using one instance of the ALTMEMPHY generated with the MegaWizard Plug-in Manager. The simulation files generated using Quartus II version 11.1sp2 or 13.0sp1 are...
12 years agoHello,
I'm also working on this. I did success in compiling my test design (which is only an ALTMEMPHY instantiation) and start a simulation. I also did choose to "skip calibration" when I configured the ALTMEMPHY. I only connected the clocks, resets and set ctl_clke to '1'. I was expected to see the mem_clk alive. However, it does not happen.... What are the minimum required things to configure/check before the ALTMEMPHY is ready to work with the controller ? Franck.
