12 years agoSimple question about SDI IP
Hi to all, I have a very simple and basic question about the SDI IP. I'm using a Cyclone V GX. I'm trying to acquire a SDI SMTPE-292M signal (HD-SDI). Do I needs have to use the reconfigurat...
11 years agofaust861, can you confirm which bits you truncated for your design from the SDI's [19:0] rx_dataout bus?
I was thinking of using bit [19:12] & [9:2] to connect to the CVI block. Is this correct?
