8 years agoSimple IP creation fail
Hello all,
I am trying to create an IP component for the need of a project (home-made avalon master ans simulation with slave BFM). Under the component editor of Platform Designer/Qsys, I run into some error when adding my hand-written master and analyzing it:
Error: Family Cyclone 10 GX is not installed
Error: Error (P0): Flow failed: Current design not found
Info:
Warning: Quartus Prime Synthesis was unsuccessful. 2 errors, 0 warnings
However, as I only want to use this component for my Arria 10-based project, I don't need any Cyclone (nor Stratix) family components. Is it possible to bypass this checks ? I would be glad not not have to install the other two families for nothing ... I attached the complete Qsys log if relevant. Thanks !1 Reply
Some update: installing the device bundle solved the issue, but this is not surprising.
However, I still would like to uninstall the ~50Gb I downloaded "just to see"! Any clue on a bypass?
