12 years agoSimple explanation of channels
Hello people, I am having an already existent Quartus II project with my custom code and I want to implement a floating point control structure with DSP builder and use it inside the custom pro...
12 years ago --- Quote Start --- if current signal is separate from voltage signals then in theory it is two information channels. When it comes to processing then if you are targeting same identical processing on each then you can use two channel settings. but if at some point you need to process them together then naturally it is one channel from processing perspective. --- Quote End --- That clears out my question and gets you a reputation star :)
