8 years agoSimple Avalon-MM to onchip memory
I have been struggling to get a simple Avalon-MM to read from an onchip memory slave. All the examples I've seen have a NIOS connect to the onchip memory which I don't want. I am putting my process...
8 years agoThank you for the replies. I did originally start with waitrequest without chipselect. My hex file is in the same directory as the QSF/QPF. While digging through the report to see if it mentions the hex file (which it never does) I noticed the LED registers being removed in the optimization step due to a related signal being stuck at GND. I've got to do some more digging to figure out what is causing that or maybe re-create the project from an Avalon-MM master template.
