SigTest 6.1.06 CLI TIE Error Message Unclear
Hi all, I'm running into an error where my test runs successfully when using the GUI but not the CLI.
I ran the following in powershell:
PS C:\Program Files\SigTest 6.1.06> .\SigTest.exe PCIe 6_0 "Base_TX_w_52UIJitterPattn" /wf "C:\Users\PragathiVenkatesh\Downloads\64G_52uijitter_d_Run000_no_deembed.bin" /xn /t 5dB_CTLE
PS C:\Program Files\SigTest 6.1.06> Test in progress, please wait......
Test has finished successfully.
Exception happened during test. Please check the log file for detailed information
It looks like the test ran successfully, but something happened when trying to create the report files/output files.
Has anyone come across this issue before? I've attached the error message log, but it isn't a very helpful error message.
Thank you,
Pragathi
- pragathi_venkatesh
Note: I also get the same error message when specifying an output file path: .\SigTest.exe PCIe 6_0 "Base_TX_w_52UIJitterPattn" /wf "C:\Users\PragathiVenkatesh\Downloads\64G_52uijitter_d_Run000_no_deembed.bin" /xn /t 5dB_CTLE /o ~/Downloads/test.out
- Wincent_Altera
Hi ,
May I know which device that you are using ? Is it altera device ?
What software that you to test the sigTest ?
Wincent_Altera
Hi Winent! I'm using a Windows 10 x64-based PC. I've tried this with SigTest 6.1.06 and 6.1.09 but run into the same issue. I use powershell to run automated tests.
Wincent* Apologies
- Wincent_Altera
Hi ,
May I know which design that you are using to perform the Sigtest ?
What is the FPGA device that you are using ? Agilex 7 device ? R-tile ?
Regards.
Wincent_Altera
Right now, we use a Keysight BERT (or equivalent pattern generator) to send the 52UI PCIe6 jitter compliance pattern.
- Wincent_Altera
Hi ,
May I know which device that you are using to run the test ? Agilex 7 device ? R-tile or P-tile ?
Above question is important for me in other to define an accurate answer towards your issue.
As far as I know Altera is not yet launching gen6 solution at the moment.
>> It seen to me like there is not related to Altera product, do you trying to reach out to Keysight support ?
Wincent_Altera
The issue is that the test runs successfully when using the SigTest GUI but fails when using SigTest CLI. This means the issue is with the SigTest CLI usage, and I'd like to know what the correct CLI arguments are.
- Wincent_Altera
Hi @pragathi_venkatesh ,
Can I please get your confirmation on below question ?
"May I know which FPGA device that you are using to run the test ? Agilex 7 device ? R-tile or P-tile ?
As far as I know Altera is not yet launching gen6 solution at the moment. "
IF you are not using any FPGA device, Perhaps you shall go to Intel community as this is out of our suppose scope in this forum (FPGA forum)
Wincent_Altera
- Wincent_Altera
As mentioned, if you are not using any Altera FPGA device, I suggest you to post the question in "Intel forum" page.
Hope the right expert will connected to you soon. Let me know if you have further question.
Wincent_Altera
