pragathi_venkatesh
1 year agoSigTest 6.1.06 CLI TIE Error Message Unclear
Hi all, I'm running into an error where my test runs successfully when using the GUI but not the CLI. I ran the following in powershell: PS C:\Program Files\SigTest 6.1.06> .\SigTest.exe PCIe 6_...
pragathi_venkatesh
1 year agoThe issue is that the test runs successfully when using the SigTest GUI but fails when using SigTest CLI. This means the issue is with the SigTest CLI usage, and I'd like to know what the correct CLI arguments are.
- Wincent_Altera1 year ago
Hi @pragathi_venkatesh ,
Can I please get your confirmation on below question ?
"May I know which FPGA device that you are using to run the test ? Agilex 7 device ? R-tile or P-tile ?
Above question is important for me in other to define an accurate answer towards your issue.
As far as I know Altera is not yet launching gen6 solution at the moment. "
IF you are not using any FPGA device, Perhaps you shall go to Intel community as this is out of our suppose scope in this forum (FPGA forum)
Wincent_Altera
