17 years agoSignal Tap and Quartus II FItter
Hi, I've completed a simulation scheme and everything is working. Now I have to test it on my Altera DE2 board so i've changed my scheme with real GPIO input and a signal tap block at the end o...
15 years agoHi Beholder,
you should be carefull adding to much signals to the SignalTap. Depending on your clock frequency (here it is like a samplerate) the Tap could use a lot of memory bits or M9k-Blocks which normally come to an end first. After Analysis & Synthesis you can take a look in your compilation report. Here you can see how many bits go down to SignalTap, even if it is not fitted. I would slow down the frequency of your sample clock if your IOs are not so fast. When the desgin is fitted you can see how many blocks & bits are used under "RAM summary" in the compilation report.
