15 years agoSignal problem, MM-SLAVE
My goal is to have a system with a Nios ii processor as a master. The processor should send data to 20 slave units, custom logic, PWM-generators. The data to be sent is just the top value for the PWM-signal. I'm completely new to this, so I've probably done tons of mistakes. Anyhow here's the VHDL code: ----------------------------------------------------- entity PWMtest is Port ( EXTCLK_I : in STD_LOGIC; -- From the 50MHz clock generator PWM_O1, PWM_O2 : out std_logic; DATA_ARRIVED : in std_logic; DATA_IN : in STD_LOGIC_VECTOR(7 downto 0) ); end PWMtest; architecture Behavioral of PWMtest is signal clk_50M : std_logic; -- we use this signal for clk signal counter : std_logic_vector(7 downto 0) := (others => '0'); signal pwm : std_logic; begin clk_50M <= EXTCLK_I; PWM_O1 <= pwm; PWM_O2 <= NOT pwm; process(clk_50M) begin --process if (clk_50M'event and clk_50M='1') then if counter < DATA_IN then pwm <= '1'; -- the pwm output is high else -- the rest of the cycle pwm <= '0'; -- the pwm output is low end if; counter <= counter+1; -- The counter just runs and runs and runs end if; end process; end Behavioral; ------------------------------------------------- I want to add that VHDL-file in to a component but I have no clue how to get this work. I've tried to read: http://www.altera.com/literature/manual/mnl_avalon_spec.pdf but it's probably not meant to be read by a newbie like me, because I didnt understand much at all. Anyhow below have I taken a screenshot of how it looks in my SOPC-builder. What signals should I have if I wanna read the DATA and then perform a PWM signal with data from the nios processor? Would be happy if someone had a tutorial or anything easier than the avalon specifications. http://img695.imageshack.us/i/sopco.jpg/ <---- Screenshot of how where I am right now in my attempt to get this to work. Regards, Mr_embeddedNo RepliesBe the first to reply
