11 years agoShare Asmi Parallel IP with Serial Flash Loader problem
Hi, I use Cyclone V E FPGA Development Kit, i successfully read and write in the EPCQ256 memory with the ASMI Parallel IP but i would like to share the Asmi Parallel IP with Serial Flash Loade...
11 years agoProblem solved.
Solution : 1- Don't use Quartus v14.0.0 build 200 Web Edition but use Quartus v14.1.0 build 186 Web Edition 2- Create a new project of all your design (don't upgrade) Antoher thing Altera Flash Loader must have always noe = 0 to have internally access to the ASMI
