SGDMA transfer data rate issue
Hi, Elisheva
May I know where you got stuck ? can you give more details ? Thanks.
Below are a few points to highlight.
-for stream to memory transfer, if burst transfer is enabled, an internal write FIFO with a depth of 2x the maximum write burst size is instantiated.
Make sure that you have enough memory otherwise it may not work.
-DMA descriptors must be initialized and aligned on a 32-bit boundary.
-address should be word-aligned.
-the last descriptor in a list must have its OWNED_BY_HW but set to 0 for the SGDMA core to stop processing. Or you can generate a EOP (end of packet) in your descriptor for an unknown transfer size.
-the transfer size should be the multiple of data width for transfer without EOP.
-write burstcount signal width is between 1 to 16, so the maximum burst write size should be 32K
-Nios2 will only initiate the transfer between RF and memory by generating descriptors, and it shouldn't transfer the data.
-make sure to set the WRITE_FIXED_ADDRESS to 0 in desc_control bit map of DMA descriptor to increment the write address after each write. And set RUN to 1 in the control register bit map to start transfer.
Eric
