11 years agoSGDMA to SDRAM speed?
[EDIT] SOLVED Hello, I'm trying to develop an accelerator for a computer vision algorithm. The host program is running on the Intel Atom on the DE2i-150 board, and is sending images ...
11 years agoA descriptor is an instruction set that the master (in your case pc) gives the DMA that describes where to access data and how much data to take. In a memory-memory application like you have, the descriptor should contain the address locations of the source data (pcie) and the sink for the data (sdram) (or vice-versa) and the number of bytes to transfer in 1 pass or burst. With the mSGDMA you can write many descriptors into the descriptor buffer (see the dispatcher) and you can command the dispatcher to chain them: so once one descriptor is complete, the dma will automatically begin working on the next one. This way you can continuously transfer data.
