13 years agoSGDMA has corrupted read data in 8-bit operation
I'm using the sgdma with 32-bit aligned read buffers as recommended but I still get corrupted read data. I haven't found any known issues about 8-bit operation. Does anyone know if 8-bit operation wo...
13 years agoGZoinker - Thanks for the suggestion. I was monitoring the read data directly (via SignalTap) going into the DMA so I know the data is bad from the start.
dsl - I think you may have got the answer! I'll check it out. Thanks!
