15 years agosfftmodel for windows 7 64-bit
I am trying to run the MATLAB testbench that mirrors the functionality of altera fft megacore for Quartus 10.1. However, I am unable to compile the autogenerated fft_tb.m file using Sfftmodel.dll and I am looking for the Sfftmodel.mexw64 version that may be used on Windows 7 (64-bit). Is there a way to get around this? Please let me know. Thank you3 Replies
I'm also interested in the solution for this issue. Please advice anyone.
I can also emphasize that this issue needs to be solved. It causes problems when someone has already matlab64 installed and tries to evaluate an FFT megacore module. This means that an mexw64 Sfftmodel has to be provided along with the mexw32 one.
Thank you - Altera_Forum
--- Quote Start --- I can also emphasize that this issue needs to be solved. It causes problems when someone has already matlab64 installed and tries to evaluate an FFT megacore module. This means that an mexw64 Sfftmodel has to be provided along with the mexw32 one. Thank you --- Quote End --- March 5th 2013 and the problem is still unsolved?!?!?!
