13 years agoset_connection_parameter_value not callable from QSYS instance script?
Hello All, I would like to embed the SGDMA descriptor on-chip ram inside of a QSYS subsystem however for this to work properly the base address of the subsystem must be passed in so that the SG...
13 years agoHi Jeffrey,
I get the same error with the "set_interface_property" and "add_interface" command and I'm still searching for a solution. Could you solve the problem already? with kind regards, MrFreshman
