16 years agoSerialLite II
Hi, I am trying the seriallite IP on the Stratix II GX signal integrity board and implement a loop back funtion with one TX and one RX. I found that when I disconnected only one of the diff...
16 years agoYou may also start to see problems at different cable lengths. You're basically going to affect the equalizer's range of equalization (because you've messed with the signal amplitude).
Jake
