16 years agoseriallie over coaxial cable
Hi all, I wonder the SerialliteII can transmit data by a coaxial cable? how will be the max length? Thanks....
16 years agoTo use available high speed IO transceivers with coaxial cables, you would need two cable pairs for each lane. This replacement of a 100 ohm differential pair by two single ended 50 ohm cables is sometimes done for SATA, SAS or PCIe, mainly in a lab for test and measurement. At the lower bandwidth corner of high speed serial links (< 1GBit/s), you can try transformer coupling or active drivers to adapt single ended cables for the link.
