14 years agoSerialite II data rate on Stratix - 4 FPGA
Dear friends STRATIX-4 FPGA which has transceivers supporting up to 8.5Gbps per lane I am planning to use Serialite II protocol but when i read the specification of Serilatite it shows onl...
14 years agoHi
Thank you very much for you kind and prompt reply One of my friend told that Serialite II supports only 6.375 Gbps Out of which if we remove 25% for all redundancy(8b/10 clock correction,alignment etc) than the RAW data rate supported by Serialite-II protocol is 4.78125 Gbps I am wandering if the link supports 8.5 Gbps than removing 25% redundancy we should reach up to 6.375 Gbps data rate I would like to know weather the above suggestion that serialite imposes a restriction even though the link supports better speed is correct or not if not I am looking for a protocol which maximum utilizes (8.5Gbps) link speed Regarding your questionWhat are you trying to implement? I need to transfer 128 Gbps(RAW) data between two FPGA's Regards M Kalyan srinivas
