16 years agoSERDES 6.25Gbps ALT2GXB rx_freqlocked
Hi All, I have two Stratix II FPGAs (in two boards) communicating through 20 SERDES channels (Basic protocol). Usually things work fine. When one of the boards is not connected, I expect that t...
16 years agoI appreciate your immediate response. That was fast!!! Thanks.
I have not enabled syncstatus signal when creating the block. I will do that and check if that solves the problem I did check rx_errdetect earlier and found that there was no error (on particular byte lanes). Regarding delaying rx_freqdetect, seems like it is stable and high for a very long time, even though it should not be receiving anything valid, But I do a digital reset (after few us delay)if I find that there is no rx_freqlocked.
