Gyud0
3 years agoSDRAM Controller FPGA IP- read x"FFFF" from the IP and not the ejected data from SDRAM
Hey,
I'm using the SDRAM Controller Intel FPGA IP for a 256Mbits device (16 bit).
When I execute a read operation via the Avalon MM interface, I see that the SDRAM eject the correct data via it's...
AdzimZM_Altera
3 years agoHi Gal,
Thank you for submitting your question in Intel Community.
I can see that you are having problem while reading from memory.
But I need to clarify some information below.
- Which SDRAM Controller IP that you are using?
- Which Quartus version and edition that you are using?
- Which device that you are working on?
- Are you using Intel Dev Kit or your own custom board?
- Are you using an example design or your own design?
- Any memory datasheet and user guide that you are referring to?
Adzim
