17 years agoSDRAM controller: Altera High Performance vs. Microtronix Multi-Port
We are in a process of choosing which one to use: the Altera High Performance SDRAM controller or the Microtronix Avalon Multi-Port SDRAM controller. Please advice, in the following factors: ...
17 years agoForam,
Which video processing blocks are you using? If you are using Altera's Deinterlacer or Frame buffer then you can force them to use a different clock domain for the memory masters than for the video processing. This would allow you to connect the memory interfaces directly to the DDR2 memory controller without using the clock crossing bridges. If you want to do this, edit the following files: C:\altera\80\ip\deinterlacer\lib\vip_dil_hwfast.hpp Change line 10 from # define DIL_MEM_MASTERS_USE_SEPARATE_CLOCK false to # define DIL_MEM_MASTERS_USE_SEPARATE_CLOCK true C:\altera\80\ip\frame_buffer\lib\vip_vfb_hwfast.hpp Change line 13 from # define VFB_MEM_MASTERS_USE_SEPARATE_CLOCK false to # define VFB_MEM_MASTERS_USE_SEPARATE_CLOCK true Then when you reopen SoPC builder you will see that the memory masters have their own clock domain and you will have to connect things accordingly. Jake
