17 years agoSDRAM Controller - Problems with reading
Hi, I have used the SDRAM Controller in SOPC. Now that I am working with the real hardware, I cannot get any data, other than 0x"FFF..F" from my SDRAM. When simulating with ModelSim, eve...
17 years agoThere are no suitable reference designs for SDRAM Controllers. They are either in Verilog (I need VHDL), or I can't see any codes and it does not compile.
When I just write a single address and read it out, it looks good. But when I write about 12 addresses and try reading out, I just get FFF.. instead of the data. My code is attached, in case you want to have a look at it (for several read/write cycles). Next think I want to try is checking the timing, try only 12.5MHz clock and reading the SDRAM Controller Documentation. What else can I do? Where can I find a working design with an SOPC SDRAM Controller in VHDL? Thanks in advance!
