17 years agoSDRAM Controller - Problems with reading
Hi, I have used the SDRAM Controller in SOPC. Now that I am working with the real hardware, I cannot get any data, other than 0x"FFF..F" from my SDRAM. When simulating with ModelSim, eve...
17 years agoI still recommend sticking a scope on all the pins of the SDRAM and checking them against what you are seeing in simulation.
If you don't have access to a quick enough scope, one solution is to start with a working design (easy in the case of the Altera dev. boards) and slowly morph it into your design.
