13 years agoSDI II Core, Reconfiguration does not work. Reconfig_busy stays low
Hi All, I'm implementing the SDI II cores in one of our new design which uses an ARRIA V and so far i'm unable to get the reconfiguration to work. What I have is: - ARRIA V starters ki...
13 years agoHi DRC,
After all on my side it was very easy to solve. I did not check the checkbox "enable channel/PLL reconfiguration" in the transceiver reconfiguration controller. this item automatically checks "Enable PLL reconfiguration support block" which is ok! All the other checkboxes are unticked except for the "enable analog controls" I hope this helps to solve your issue.
