15 years agoSD SDI output not working
My design consists of the following IP blocks , and I have not been able to make it to work (no image output). The design objective is to convert 20 bits progressive parallel data to SD SDI and displ...
15 years agoHello Jimmy
You could try to use the test_pattern_generator to feed the CVO only and see if it's working properly with your SDI output. Regards, Thiago
