15 years agoSD-SDI 8bit
Hello, SD-SDI megacore supports SD-SDI 10bit mode, however I need 8 bit support. Is it possible to use 8bit mode or it will be impossible to sync the signal? If two LSB bits will be left unconnect...
11 years agoHello,
I had the same issue. I asked my Altera Supplier and he told me that the IP can only output 20 bit, even if the standard is also for 16 bit. Simply I truncated them. All went well for me. Bye
