15 years agoSD-SDI 8bit
Hello, SD-SDI megacore supports SD-SDI 10bit mode, however I need 8 bit support. Is it possible to use 8bit mode or it will be impossible to sync the signal? If two LSB bits will be left unconnect...
11 years agoNot wit sure what your talking a about, but if its sd video, connect you r 8 bits to north 9:2 and 19:12. Then you can connect 1:0 and 11:10 to 7:6 of your video.
