15 years agoSD-SDI 8bit
Hello, SD-SDI megacore supports SD-SDI 10bit mode, however I need 8 bit support. Is it possible to use 8bit mode or it will be impossible to sync the signal? If two LSB bits will be left unconnect...
15 years agoHi,
The SDI standard is requiring the support for both 10bit and 8 bit equipment. For example the synchronization words: " Each timing reference signal consists of a four-word sequence in the following format: 3FFh 000h 000h XYZh Because of the existence of both 8- and 10-bit equipment, for detection purposes all values in the ranges 000h-003h and 3FCh-3FFh must be considered equivalent to 000h and 3FFh, respectively." Since Altera declare that the SDI IP is compatible to the standard, probably they support both 8- and 10-bit equipment. BR,
