MamaSaru's avatar
MamaSaru
5 years ago
SCL_LOW, SCL_HIGH, SDA_HOLD register value of Intel FPGA Avalon I2C Master Core
How can I determine SCL_LOW, SCL_HIGH, SDA_HOLD register value of Intel FPGA Avalon I2C Master Core?
I am planning to initialize the Core from my own designed sequencer.
Thank you.
  • MamaSaru's avatar
    MamaSaru
    I have a simple question for SDA_HOLD.
    1. is this timing spec when SDA as output or as input?
    2. is this timing spec for start/stop condition or data transfer?
  • MamaSaru's avatar
    MamaSaru
    No, I mentioned register value not the register location.
    I am expecting all these timing is the timing while master driving SCL and SDA by itself.
    I easily determine SCL_LOW and SCL_HIGH to define SCL waveform.
    But I don't get what SDA_HOLD is.
    I expect it is the time to sustain SDA from SCL low or high.
  • Let's say with a 100MHz input clock and the I2C Master is operating in normal mode of 100KHz.
    For SCL_HIGH and SCL_LOW, the register value is (10us/10ns) divide by 2 assuming high and low is same (duty cycle 50:50). For SDA_HOLD, it is (your desired hold period/10ns).
