17 years agoscaler usage in run time control
I am using vip suite 9.0 and quartus 9.0 for out new project. I am able to process frames with scaler in static parameters mode there is problem with runtime controle mode.I had following ...
16 years agoAll addresses in SoPC builder are byte addresses. So for example, if you had a scaler located at base address 0; register 0 of the scaler would be located at address 0 but register 1 would be located at address 4. Maybe you could send me a screenshot of your SoPC system?
Also, the address space of the scaler will change depending on which scaling algorithm you have selected. I think there are only 4 addresses for the bilinear and nearest neighbor algorithm but it increases for the polyphasic. Jake
