16 years agoscaler problem
Hi, I have another problem about scaler, it's right that adding a control port to scaler makes the input resolution changable, but some resolution doesn't work. My data path is listed below. Clo...
15 years ago --- Quote Start --- Hello Mike, Can you give us more information regarding the Scaler: The Scaler clock? The number of bits per component (R, G, B )? The bus to the Scaler - parallel or serial? BR, --- Quote End --- Hi Reuven, The scaler clock is 200MHz. 24 bit (8 per component RGB ). The bus in/out of the scaler is parallel. Thanks, Mike
