16 years agoscaler problem
Hi, I have another problem about scaler, it's right that adding a control port to scaler makes the input resolution changable, but some resolution doesn't work. My data path is listed below. Clo...
15 years ago --- Quote Start --- If all configurations are OK, maybe you have memory bandwidth problem? The frame buffer need to access the memory much more frequently at 1600 x 1200 then in 1280 x 1024. At 1600 x 1200 x 24bit x 60Hz input & output to the frame buffer you need very high memory bandwidth. Can you give us the details of the SDRAM (DDR) you are connecting to the FB? --- Quote End --- Thanks for the feedback, Attached please find settings for the SDRAM. Please let me know if any more info is needed. Thanks, Mike
