16 years agoscaler problem
Hi, I have another problem about scaler, it's right that adding a control port to scaler makes the input resolution changable, but some resolution doesn't work. My data path is listed below. Clo...
15 years agoYou may have done that step already but before you start looking at memory bandwidth issues you should probably try whether the following is working to rule out issues with the CVO:
TPG@1600x1200 -> CVO
