16 years agoscaler problem
Hi, I have another problem about scaler, it's right that adding a control port to scaler makes the input resolution changable, but some resolution doesn't work. My data path is listed below. Clo...
15 years agoHi Everyone,
Just wanted to provide some status for the scaler problem at 800x600 -> 1600x1200 scaling. I replaced the CVI with a test pattern unit and still have the same problem. The video path is the following: TP@800x600x60Hz -> SCALER -> FRAMEBUFFER -> CVO The following scaling tests: 800x600 -> 1024x768 OK 800x600 -> 1280x1024 OK 800x600 -> 1600x1200 Broken!! It looks like the problem is in either the frame buffer or the CVO. Can one of the Altera guru's please provide some guidance here??? It's looking like a throughput issue post-scaler, what parameter would make sense to change in the CVO & Frame Buffer?? Thanks, Mike
