16 years agoscaler problem
Hi, I have another problem about scaler, it's right that adding a control port to scaler makes the input resolution changable, but some resolution doesn't work. My data path is listed below. Clo...
15 years agoHello,
I would try setting the Scaler to a simple Bilinear and then if it is working go up step by step from 5 tap to 12 taps (as you need). What about the Frame buffer is it a double buffer or a triple buffer? Good luck,
