16 years agoscaler problem
Hi, I have another problem about scaler, it's right that adding a control port to scaler makes the input resolution changable, but some resolution doesn't work. My data path is listed below. Clo...
15 years agoThe number of lines in the cvi is related to your upscale ratio (see Jake's answer above). I think you will be fine if you use (output_height / input_height) + 2 or 3 lines but you really need to give it a try.
I do not think this system can work with the cvi if it does not work with the tpg.
