16 years agoscaler problem
Hi, I have another problem about scaler, it's right that adding a control port to scaler makes the input resolution changable, but some resolution doesn't work. My data path is listed below. Clo...
15 years ago --- Quote Start --- Hi, As pointed out by Sean, the cvi->scaler->vfb->cvo designs may not work because the cvi is overflowing. You can try moving the vfb before the scaler or increase the number of lines of buffering in the cvi. I still have no idea why the tpg->scaler->vfb->cvo design stops working when adding the scaler. Did you use 1080p or 800x600 in the tpg->vfb->cvo design that works? Please try it with 1080p if you did not already. --- Quote End --- Hi vgs; thank you for reply. I tried the 1080P with tpg->vfb->cvo. How to define the number of lines buffered in the cvi ? Rabia
