16 years agoscaler problem
Hi, I have another problem about scaler, it's right that adding a control port to scaler makes the input resolution changable, but some resolution doesn't work. My data path is listed below. Clo...
15 years ago --- Quote Start --- Hi, Is there any overflow or underflow occured when you insert a scaler? If a overflow occured, may be you could increase the buffer of the cvi. Sean --- Quote End --- Hi Sean; Yes I have an overflow on the CVI, how can I determine the value of the buffer in the CVI ? thx Rabia
