16 years agoscaler problem
Hi, I have another problem about scaler, it's right that adding a control port to scaler makes the input resolution changable, but some resolution doesn't work. My data path is listed below. Clo...
15 years agoHi,
As pointed out by Sean, the cvi->scaler->vfb->cvo designs may not work because the cvi is overflowing. You can try moving the vfb before the scaler or increase the number of lines of buffering in the cvi. I still have no idea why the tpg->scaler->vfb->cvo design stops working when adding the scaler. Did you use 1080p or 800x600 in the tpg->vfb->cvo design that works? Please try it with 1080p if you did not already.
