16 years agoscaler problem
Hi, I have another problem about scaler, it's right that adding a control port to scaler makes the input resolution changable, but some resolution doesn't work. My data path is listed below. Clo...
15 years ago --- Quote Start --- Hi vgs; sorry for the delay. Here are the snapshots of the different IPs used in the design. I have made also a frame buffer using cvi->fb->cvo, it works perfectly, but when I insert a scaler between the cvi and the scaler I don't get anything. Thanks.:) --- Quote End --- Hi, Is there any overflow or underflow occured when you insert a scaler? If a overflow occured, may be you could increase the buffer of the cvi. Sean
