16 years agoscaler problem
Hi, I have another problem about scaler, it's right that adding a control port to scaler makes the input resolution changable, but some resolution doesn't work. My data path is listed below. Clo...
16 years agoCould you give the parameterizations (or GUI screenshots) you are using for the design that does not work?
Did you make any changes to the TPG, FrameBuffer, CVO parameterization when you added the scaler in?
