16 years agoscaler problem
Hi, I have another problem about scaler, it's right that adding a control port to scaler makes the input resolution changable, but some resolution doesn't work. My data path is listed below. Clo...
16 years agoHi vgs;
thank you for your reply. I've already done the different steps you said. I started with the TPG-> CVO, it was working perfectly. TPG -> frame buffer -> CVO works perfectly. TPG -> scaler -> frame buffer -> CVO does not work. could you guide to to get it working properley? thanks! Rabia
