16 years agoscaler problem
Hi, I have another problem about scaler, it's right that adding a control port to scaler makes the input resolution changable, but some resolution doesn't work. My data path is listed below. Clo...
16 years agoHi,
lots of things could be wrong in this system. You need to get this system working first: TPG->CVO (where TPG is the test pattern generator) Then you can try: TPG->frame buffer->CVO Then: TPG->scaler->frame buffer->CVO And finally: CVI->scaler->frame buffer->CVO
