15 years agoScaler II vs Scaler problems
Hi, I have a working video processing design that includes the Scaler (v 9.1sp2). In the design I need to convert from 4:2:2 to 4:4:4, scale the video, and then go back to 4:2:2. With the Sc...
15 years agoHi Kieron,
Sorry to bother you again, but I have question regarding dynamic addressing. If my system contains a mixture of 32 and 16 bit slaves, and I have a 32-bit master, then if I write to a 16-bit slave, I will always write to two 16-bit registers as I understand it. If the slave has 4 registers starting at 0x0000, then writing to 0x0000 would write to slave register 0 and 1, and writing to address 0x0004 would write to slave register 2 and 3? Would writing to 0x0002 write to slave register 1 and 2? Would it be possible to write to a singel 16-bit slave register? The problem is that I may not want to write to a particalar 16-bit register (it may adversely affect the operation of the slave) and it seems as if it is not possible to single out specific 16-bit registers on the slave. Regards, Niki
