11 years agoSample rate problem with Output Block of DSP Builder
Hello <br>
<br> I have a sample rate problem with the Input or Output Block (sInOut S-function block) when I try to simulate my model in Matlab.<br> <br> After this kind of block, it is always convert the sample rate of my signal to 1 second. <br> <br> Here an example of my problem :<br> <br> Here a part of my model, a put two scope : scope2 with an audio signal and scope1 with the signal after the Output Block.<br> <br> <img src="http://www.alteraforum.com/forum/attachment.php?attachmentid=9844&stc=1" border="0" alt=""><br> An image of the Scope 2 with the Audio signal :<br> <br> <img src="http://www.alteraforum.com/forum/attachment.php?attachmentid=9845&stc=1" border="0" alt=""><br> <br> An image of the Scope 1 whith the signal after the Output Block.<br> <img src="http://www.alteraforum.com/forum/attachment.php?attachmentid=9846&stc=1" border="0" alt=""><br> <br> As you can see, the sample rate was shrink to 1 second so I miss all the details of my signal. <br> <br> How can I fix it ?<br> <br> Thanks a lot for your help, I've working for hours on this problem. <br> <br> I send you my entire project attached to this post.<br> <br> YannNo RepliesBe the first to reply
