11 years agoSample rate problem with Output Block of DSP Builder
Hello
I have a sample rate problem with the Input or Output Block (sInOut S-function block) when I try to simulate my model in Matlab. After this kind of block, it is always convert the sample rate of my signal to 1 second. Here an example of my problem : Here a part of my model, a put two scope : scope2 with an audio signal and scope1 with the signal after the Output Block. http://www.alteraforum.com/forum/attachment.php?attachmentid=9844&stc=1 An image of the Scope 2 with the Audio signal : http://www.alteraforum.com/forum/attachment.php?attachmentid=9845&stc=1 An image of the Scope 1 whith the signal after the Output Block. http://www.alteraforum.com/forum/attachment.php?attachmentid=9846&stc=1 As you can see, the sample rate was shrink to 1 second so I miss all the details of my signal. How can I fix it ? Thanks a lot for your help, I've working for hours on this problem. I send you my entire project attached to this post. YannNo RepliesBe the first to reply
