16 years agorx phase compensation fifo
Hi there, I am working on a design uses an ALTGX IP in a Arria II GX device and got the following error in the fitting: Error: Input port CORECLK of GXB Receiver channel PCS "fiber_trx_lev...
15 years agoHi Oliver,
We didn't check the quality of the rx_clkout because we decided to use a local clock as our core clock for several reasons besides the jitter concern. And I actually can't remember where I got this jitter concern from, it may be from some talks we had with the local tech support team from Arrow. You might want to check with Altera directly about this, maybe the pll in CDR circuit is good enough to provide the quality you want. Regards, Hua
