16 years agorx phase compensation fifo
Hi there, I am working on a design uses an ALTGX IP in a Arria II GX device and got the following error in the fitting: Error: Input port CORECLK of GXB Receiver channel PCS "fiber_trx_lev...
16 years agoTried that too, still doesn't work.
But from the attached screenshot, which is taken from the Arria II GX Device handbook Volume 2 Chapter 2 p.g. 2-18 figure 2-11, the MUX circled in red seems to suggest that Altera does provide the control to choose a clock from the Fabric over the clock from the CDR for the read side of the rx phase compensation fifo. I was going to use a pll in the Fabric to attenuate the jitter in the recovered clock and then fit right back to the phase compensation fifo, so there should be a 0ppm clock difference. Now back to my question 1 in my post 1: 1. what is the purpose of phase compensation fifo if the input and output has to use the same clock, the rx_clkout (i.e. the recovered clock)? I thought the phase compensation fifo is the place where the rx data path crosses clock domain boundary to my core/fabric logic. Am I understanding this wrong? Any comments will be appreciated. Hua
