15 years agoRunning IIROrder2 demo
Hi dears,
I need your urgent help please. I'm trying to run IIROrder2 module which is in the Demos folder in the examples of DSP Builder, but the following error appears: Error evaluating 'InitFcn' callback of block_diagram 'topiir'. Undefined variable "com" or class "com.altera.dspbuilder.simulation.Cache.createModel". Thanks.6 Replies
This means DSP Builder is likely not installed properly.
Try re-installing. - Altera_Forum
Thanks for your reply.
I do so, I re-installed it but same error appers. I use Win7 64-bit and I install matlab 2010a 64-bit , and Quartus II 7.2, and DSP Builder 10.1. Are there any thing may affect running the module? Thanks alot. - Altera_Forum
DSP Builder 10.1 does not support 64-bit MATLAB. You need to install the 32-bit version of MATLAB.
In addition you can't use DSP Builder 10.1 in conjunction with Quartus II 7.2.
You mean that I can't use version 7.2 of Quartus II , what should it be plz? - Altera_Forum
You should use Quartus 10.1. DSP Builder is installed as part of Quartus. It is only compatible with a Quartus that has the same version number.
